I just picked me up a 660ti, was playing some battle field today and was watching afterburner. which was saying my gpu was running at 100%. so i turned the graphics down, and kept turning them down till it was all on low. yet it was still running at 100%, this was with the game running on one 1080 screen and afterburner on another, i later unplugged the 2nd screen and it made no difference.
any idea? surly even on low is shouldn't be running at 95% constantly except for loading screens where it drops instantly to like 5% then straight back up
any ideas, could it be my power supply? i have a '600w' but its a shit 600w lol could it not be getting enough juice? on afterburner ive got the power limit set to 100 (range 76-123) the temp hardly rises aswel
any ideas? it just doesnt seem right, i went over my cap downloading bf3 so its the only game i have to test at this stage
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
It's completely normal.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
but my 560 could at least run medium with out running 100%? like, its really bad with this card, its not laggy or anything. infact its not laggy when i run it on high and the fps is okay, im just curious as to why its always running so hard when playing it? like normally i would get some fluxuation like with explosions and shit, now, nothing its always running flat out no matter what the graphic settings are on...
PSN: Rcp_soundz
It's probably more efficient at using all of it's horsepower than the 560. Are your temps okay? If so, then forget about it.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
yeah my temps are fine so far... thanks man, it just seemed a bit strange
PSN: Rcp_soundz
Do you have V-sync toggled off? V-sync (vertical sync) reads the vertical refresh rate (Hz, or max FPS your monitor can display) of your monitor and forces the GPU to cap the frames per second that it draws at that number. If you have a 60Hz monitor (standard refresh rate) then the GPU will be capped at 60 FPS and the GPU shouldn't run at 100% usage. If you toggle off V-sync then you're telling the GPU "draw as many frames as you can per second", in which case the card will just run at 100% and draw more than 60 FPS if it's capable of it.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
hmmm interesting. ill have a look man, thanks
PSN: Rcp_soundz
that made a huge difference! can run high now with only 80% usage
PSN: Rcp_soundz
Glad to hear it!
wtf is lolcats?
  • 3 weeks later...
but doesn't it feel sluggish??
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
  • Who's Online   1 Member, 0 Anonymous, 1810 Guests (See full list)
