Jessica Posted July 15, 2013 Report Posted July 15, 2013 yes Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
2010gmc Posted July 16, 2013 Author Report Posted July 16, 2013 Well my box would be hard to fiberglass without taking it apart, so is probably just build another one. Can anyone tell what gauge my wire is? And also does the size of the wire from the amp to the sub matter very much?
Quiet Posted July 16, 2013 Report Posted July 16, 2013 no it wouldn't. right where you have that foam in the box, lift that up, lay down some fiberglass mat and coat with resin. It'll dry really hard and should hold it all together pretty well. You can pick up enough stuff to do that little job at walmart for less than $20. 2007 Pacifica Rebuild. Less quiet. Still not loud.
Quiet Posted July 16, 2013 Report Posted July 16, 2013 Your power wire looks like 8 gauge from the outside. Just look on the jacket for the print, should say about every foot or so. And your speaker wire looks like 16 gauge, which is fine for a couple hundred watts. If you upgrade subs I'd bump up to 12 or 10 depending on the power you plan on sending it. 2007 Pacifica Rebuild. Less quiet. Still not loud.
2010gmc Posted July 17, 2013 Author Report Posted July 17, 2013 Fiberglassing the recessed areas is not a bad idea but there already a right fit with the magnet of the sub
Quiet Posted July 17, 2013 Report Posted July 17, 2013 get a pack of modeling clay and fill the pocket. Mount the sub and you can see exactly how much room you need. 1/4" should do nicely. 2007 Pacifica Rebuild. Less quiet. Still not loud.
2010gmc Posted July 17, 2013 Author Report Posted July 17, 2013 Ok I should probably cover the sub with plastic right
Quiet Posted July 17, 2013 Report Posted July 17, 2013 lol that's a given. cerran wrap should do it. 2007 Pacifica Rebuild. Less quiet. Still not loud.
