XxshadowdawgxX Posted July 13, 2013 Report Posted July 13, 2013 I just recently installed a custom made 12'' with a Fi BTL UFO motor. The sub is a dual 1 and is wired down to 2 ohms. The subwoofer is getting incredibly hot very quickly after very short amount of play time and power for that fact. The subwoofer isn't even nearing its full potential. I have a stock front battery with a concept isolator/regulator feeding two kinetik 2400's. The amplifier running it is a Kicker KX2500.1. Theory 1: I didn't realize the touchscreen I bought is a 2v preout, so therefore I'm having to increase the gain on my amplifier way higher than I've ever had to before, not sure if that is what is causing it. Theory 2: I had to change my isolator/regulator totally in my new car from my old car. It wouldn't wire up correctly in my chevy cruze so I had to make a regulator. I've realized the front battery will charge the kinetiks like its suppose to, but then the fucking kinetiks will recharge the front battery before the alternator even gets chance to charge the front battery. Please do not comment about the battery brand or the fact the amplifier is a kicker or anything. Looking for just a legit answer not a lecture on how I should have XS power or anything ( if i didn't already have the kinetiks I'd have XS). Thank you and please comment as much as you feel. Needing answers asap! Any other theories are very much welcome!
MrSkippyJ Posted July 13, 2013 Report Posted July 13, 2013 Could be a few things. I would start with taking the isolator out. then check how accurately you set your gains. Once that is done, check the voltage at your amp when music is playing and see if you have any major voltage drops. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
XxshadowdawgxX Posted July 13, 2013 Author Report Posted July 13, 2013 Could be a few things. I would start with taking the isolator out. then check how accurately you set your gains. Once that is done, check the voltage at your amp when music is playing and see if you have any major voltage drops. The gains aren't set very accurately I'm assuming considering I'll stick the gain at 1/2 and the sub is hardly moving and gets hot. Also when you say major voltage drop, how much voltage drop are you talking about?
fox_racin4 Posted July 13, 2013 Report Posted July 13, 2013 Sub wired wrong? Pop test it with 12v and see which way it moves, My fully loaded BTLs took 7k no issues 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
XxshadowdawgxX Posted July 13, 2013 Author Report Posted July 13, 2013 Sub wired wrong? Pop test it with 12v and see which way it moves, My fully loaded BTLs took 7k no issues How could it be wired wrong exactly? I mean its pos to amp/ neg to amp. with a jumper from pos to neg.
fox_racin4 Posted July 13, 2013 Report Posted July 13, 2013 Jumper could be on wrong If its hardly moving off 2500rms You hVe a problem more then likly woth the wiring 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
XxshadowdawgxX Posted July 13, 2013 Author Report Posted July 13, 2013 Jumper could be on wrong If its hardly moving off 2500rms You hVe a problem more then likly woth the wiring What do you mean the jumper could be on wrong? Never knew it could be. Please elaborate, I'm terrified about blowing my brand new sub.
fox_racin4 Posted July 13, 2013 Report Posted July 13, 2013 Terminals could be labeld wrong. Pop test the sub. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
XxshadowdawgxX Posted July 13, 2013 Author Report Posted July 13, 2013 Terminals could be labeld wrong. Pop test the sub. I trust the person who made the subwoofer to not have screwed that up. I use a 9v I'm assuming though to test it?
fox_racin4 Posted July 13, 2013 Report Posted July 13, 2013 Could be the coil itself... I use 12v I unhook leads from and And touch to power input terminals 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
