Maybe someone can help me out here. I have a 1990 dodge Dakota with a single sa 12 running on a hifonics Brutus 1200 with zero gauge wiring. I've noticed sometimes when I start the truck the volt meter seems a little low. When this happens the sub doesn't seem to hit as hard as normal. After driving for 15 minutes or so the gauge will flip out for about 5-10 seconds and the headlights dim and flicker and the truck starts charging above 15. All my grounds and connections are good on bare metal with no paint. Only thing I can think of is the ground from the battery to the body is very thin. Very very thin. My speaker wire is thicker lol. Could this be the issue?
its possible that is the issue. a lot of stock charging systems sucked back in the day. try doing the big 3 in 4 gauge or 0 gauge if you plan on upgrading in the future and see if that solves your problem.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I would think if that's not the problem your alternator's regulator might be faulty.
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Replaced ground cable from battery to frame and voltage is steady even full tilt.
good work. glad it helped out. almost everytime i see one of these its a ground issue somewhere.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 541 Guests (See full list)
