S10 Blow Through, 4 Mayhem's, First Video & Voltage Drop Issues :(
Im trying to have Brandon make this a walk through.
What say you all? ??
at least, use a shell, and not a tonneau cover... meh...
I thought about doing that too,get a shell and remove the rear window so no damage to the truck itself would be done.
I say if you have the $ and or skills then get the shell and use rear window for the blow through. You'll be using the waterproof the same way just at the top,it will salvage the truck value if you do it that way. Don't be skeered,just do it.
Tuned in for sure,I've got a 03 ext cab S10 xtreme and want to do a cut through myself with either 4 or 6 12's. Looking good so far,nice equipment choices.. BTW you can fit a D3400 under the hood,Mechman told me it would fit and it did..2013-03-10194158_zpse1bafbb8.jpg
is the engine room the same as a 94?
Alpine CDE-HD149BT Head Unit
Hertz HSK 165XL
Audison SR4 (Running the Hertz 6.5)
Audison SR2 (Running the Hertz Tweets)
Ascendant Audio Mayhems 4- 12" (Being Built)
DC 7.5K
230 AMP Singer ALT
6 XS-D3000 Batteries (Back) (In the works)
1-XS-D3400 Battery (Front)
Lots of SHCA Wire and Accessories.
Camper shells are not cheap, and trying to find a used one that is somewhat matching and is not a grandpa shell is not easy.
Hertz HSK 165XL
DC 7.5K
230 AMP Singer ALT
Camper shells are not cheap, and trying to find one that is somewhat matching and is not a grandpa shell is not easy.
neither are good quality tonneau covers
