green yellow gas feom fuel rail?
first as you can probably guess its a 95 dodge neon base model.auto tranny.
ok so I've been having a problem with this vehicle on longish trips get a ways and she will spit and sputter the first tim you get to a stop. I had this happen today driving local.
I thought the fuel tank was vapor locking so I've had the fuel tank cap loose since a week ago abouts. normally you let it sit a while and she'll get back to driving and running normally.
so I putt putted home today. I pulled up and raised the hood. and said wtf? cussed at her a few times. I went in the garage and got a drill bit and pressed the lil nipple pictured below. its on the fuel rail so I figured maybe low pressure or lack of gas so i was gonna check for fuel in the rail... nope I tapped it and the gas was a weird ass green color. or a darker yellow. could the corn fuel that's in the cheaper gas around iowa be messing up my fuel system? what could color it like that?
any who I got what I could of that crap out of the fuel rail and turned the key on to start the fuel pump got it back to pressure and started her up... she started fine and ran well... what's up with this shit? I'm frustrated!
here's where I got the green yellow gas from.
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
its a normal clear if any color its a light yellow light brown but mostly like water... but I tend to buy the cheap stuff and it has ethanol in it... ill probably stop using that.
the fuel filter is at very most 2000 miles old. may be in need of a change. I drive about 60 miles a day four days a week for work. and that's the majority of my driving. would that cause it to be a weird color? Also, if it was a clogged filter wouldn't it act up right from the start? or might it be a thing where it runs rough after the pump starts getting warmed up and starts fatiguing a lil bit?
I found out the pressure regulator is in the tank too right next to the pump... who makes these decisions lmno.
ok I think I'm going to hit advanced and borrow a fuel pressure gauge to see if this is giving me proper fuel pressure. if not ill check it pre filter and probably replace it... I'm kinda thinking my pump may be shot... I took it around the block just now and didn't make it half way back to the house and she started acting up... so off to advance soon as the other car gets back
ok jist got a fuel pressure tester... I have 30 psi at the rail... fuck... ime gonna check my filter right now
The color thing is fucking weird.
I agree! that has me quite puzzled....
Just a thought have you ever ran like octane booster through it ive read before that is fucks with fuel dilters and clogs them
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
New screen next to old screen.
A possibility of the intermittent putt putt is that the pump screen inside the fuel tank is full of trash and blocking fuel flow.
I speak from experience.
Old, clogged up screen. In this case it got to the point where the screen itself started getting sucked into the fuel pump.
oh shit! dude that's horrid! how old was that filter? just curious. hmmm... yeah I fear I may have to replace the fuel tank internals. 183 for the whole assembly. but if it turns out to be the filter clogged and I have to replace that too it'll irritate me lol
