Tnop Posted July 17, 2013 Report Posted July 17, 2013 I recently bought 4 creshendo pwx 6.5 speakers they will be powered by a creshendo 1100.4 amp and i will be running them for my front stage but i am having problems with clarity i can not get it to sound right i currently have 2 of the four speakers hooked up.
White Lightning Posted July 17, 2013 Report Posted July 17, 2013 are the drivers installed into the vehicle properly ?? did you wire them up correctly ??? one driver on each chanel ?? are you running tweeters ?? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Bump4life Posted July 17, 2013 Report Posted July 17, 2013 sounds dirty and not clear at all volumes? or just at low volumes? or just at high volumes? Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
darkjds Posted July 17, 2013 Report Posted July 17, 2013 make sure u dont have ur amp set to low pass Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
Tnop Posted July 17, 2013 Author Report Posted July 17, 2013 are the drivers installed into the vehicle properly ?? did you wire them up correctly ??? one driver on each chanel ?? are you running tweeters ?? yes the drivers are installed properly. They are wired up correctly.1 driver on each channel only two of the four are connected. no tweeters
Bump4life Posted July 17, 2013 Report Posted July 17, 2013 those speakers dont play everything. you need tweeters with those. and you need crossover points set correctly. especially with a PA driver. set a Low pass filter on them around 4500 hz or possibly down to 3500 hz depending on how low your tweets can go. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Tnop Posted July 17, 2013 Author Report Posted July 17, 2013 sounds dirty and not clear at all volumes? or just at low volumes? or just at high volumes? It sounds clear on low volume but when you turn it up it sounds dirty. i turned the down gains it still sound the same.
Bump4life Posted July 17, 2013 Report Posted July 17, 2013 sounds like your crossovers arent set right or you are over driving speakers. this all comes down to how loud you listen to your music and what tone you like. but start with your crossovers at: LPF (if applicable) : at 4500hz HPF: 80hz see how that sounds. make adjustments from there. to get smaller PA style speakers to sound good I HIGHLY reccommend running active. with bandpass filters. (HPF + LPF on) Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Tnop Posted July 17, 2013 Author Report Posted July 17, 2013 sounds like your crossovers arent set right or you are over driving speakers. this all comes down to how loud you listen to your music and what tone you like. but start with your crossovers at: LPF (if applicable) : at 4500hz HPF: 80hz see how that sounds. make adjustments from there. to get smaller PA style speakers to sound good I HIGHLY reccommend running active. with bandpass filters. (HPF + LPF on I will try your recomendation and see if it works. i will also post some pictures later
