SnowDrifter Posted July 21, 2013 Report Share Posted July 21, 2013 That 3 amp reading you have is normal. Just gotta zero the meter As to the smoking wire: look into that IMMIDIATELY. What wire is it? I'm assuming it's a wire since I didn't hear any belt slip. That may be indicative of your low voltage though. Double check all of your connections, take them off, make sure there is no corrosion or anything and that they have solid contact to the metal underneath You said your voltage was 12.8v for this test? That's what I would expect to see. Not the 11.8v that was present before. Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Shigshwa Posted July 22, 2013 Author Report Share Posted July 22, 2013 (edited) Looks like I've figured it out. a rubber sleeve from my alternator wire got caught in between the terminals, and started smoking up. Edited July 22, 2013 by Shigshwa Quote Link to comment Share on other sites More sharing options...
Shigshwa Posted July 22, 2013 Author Report Share Posted July 22, 2013 Alright guys, I've ordered the 3100. I'll report the results! Quote Link to comment Share on other sites More sharing options...
