Keveeno Posted July 23, 2013 Report Posted July 23, 2013 Just got my aftermarket alternator in from Ohio generator. The alt will do 160 at idle and ramp up to 320 at full tilt. I have a 0 gauge run that will be installed between the alt and the front battery. It had occurred to me that the 300 amp anl fuse probably won't be big enough, or will it? At 5000 rims, the alt will start to put out over 300 amps to the first battery. Any suggestions? I am using the kolossus fleks cable ofc. The cable is rated for 300 amps if that changes anything.
Karkov Posted July 23, 2013 Report Posted July 23, 2013 300 is just right IMO 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Agreene Posted July 23, 2013 Report Posted July 23, 2013 I would suggest installing another run of 0 gauge that's quite a bit of amperage for 1 run... and fuse both runs with a 300 amp fuse .... if not bump up to 350 on the single or stay as is...
Keveeno Posted July 23, 2013 Author Report Posted July 23, 2013 I would suggest installing another run of 0 gauge that's quite a bit of amperage for 1 run... and fuse both runs with a 300 amp fuse .... if not bump up to 350 on the single or stay as is...i didn't think about running another run of 0 gauge, good idea but wouldn't the load be split between the two runs so two runs of 0 gauge with like 200 amp fuses?
