if too small of a fuse is used will the amp be limited on what it can draw or will the fuse just blow when the amp pulls more current?
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
The amp will draw whatever current it needs. If the fuse inst rated to handle that current flow it will pop
Rolex you sicken me.
Just let me finish my pie
~ Juice
ok. the shop that installed my amp put a 100a fuse under the hood and 160a from rear batt to amp and thats for a aq3500. so far no blown fuses
many reason for that. The main, in my opinion, is because the amp will draw the greatest current from the rear battery. the run from the front to the rear is more of a charging lead than power so they gave it the lower fuse rating.
~ Juice
on that note, I just looked up the amp and it calls for 380 amps of current. With that said, either it isn't wired down low enough to demand full current or your just a turn of the volume away from a blown fuse!
From the AQ website:
Description
The Q1-3500D.1 is one of our most powerful Amplifier with up to 7500 watts @ 1ohm @ 18volts for those guys and ladies who want to push their systems to the limit. You can strap a pair of Q1-3500D.1'S for a woofer busting 15000 watts @ 2ohm. Born in the same place as our popular Q1-1200D and Q1-2200D and built with the very best parts money can buy the Q1-3500D.1 offers the best watt per dollar value in its power range.
WARNING
You MUST have an upgraded electrical system sufficient to provide the amperage required to handle the 380 amp fuse rating of the Q1-3500D.1 (760 amps for a pair) in order to satisfy this beast.
~ Juice
yea thats why i was wondering what would happen. if its just a blown fuse i guess that isnt that big of a issue but it def bangs. atleast enough to make me happy. i believe its wired at 1ohm. they told me thats what they were wiring to.
any way you slice it, if that 160 isn't blowing it means the amp isn't drawing more than that so your GTG!
~ Juice
ok. will try to fig it out later. i havent turnt it all the way up either. my gains r set with a dmm thats the main reason i wont test the limits just yet.
Rear batt to amp? A single 160a fuse? Or a pair of 160a fuses?
Did they use both inputs on the amp or just one?
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
