My gains are set with the SMD DD1, That's not the issue. I am running 2 Kicker ZX2500.1's and they are both set at 2720 watts @ 30hz no distortion there. (we tested it on a shops system) We also tested my head unit for distortion, It starts to distort at 20/35 with the EQ at mid. It's just a junk ol' $80 head unit.
The EQ should be flat when using the DD-1. I'm guessing this is the EQ on the head unit. you will probably see a higher volume number before distortion if you make the EQ flat.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
By mid I mean in the middle, -8 to +8 so at 0. Its an old Kenwood, but I'm not sure on the model.
'03 Cavalier LS Coup
DC Power 270xp alt
2 Sundown Neo Pro 8's
2 Selenium ST200 tweeters
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
1 CT Sounds AT7000.1D
I've never had any problems with any of my kenwood's. Granted I've only purchased excelon models, usually in the middle of the series eith 5,6,7 of model numbers, so not the highest ones either. Although I have friends who have had no issues with non excelon models either.
You'll be fine with any good Kenwood, Pioneer or Alpine as long as you find one that has the features your looking for. It's really just a personal choice on which you prefer.
most head units distort at some point. if it distorts at 20, then set your gains at 19.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
All head units distort at some point. if it distorts at 20, then set your gains at 19.
The point of this post is to get ideas on head units that wont distort on me. even at max
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
ahhhhh. well I know eclipse head units are known for never distorting but they can be a bit hard to find. you may want to look into getting a line driver.
Pioneer HU
I'll check into that! thanks
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
  • Who's Online   1 Member, 0 Anonymous, 754 Guests (See full list)
