Ported Enclosure help for 10" Mojo
Hello, First note I appologize for any and all bad spelling and grammer lol!
I am new to ported box building and need major help. For starters I listen to just about anythink as far as music and not much for constant high volume, but i do enjoy a good consistancy of bass. I have gone through 5 subs in past 3yrs. So far 4 had been Alpine Type R's and put in boxes that where recommended from both reviews as well through tuning calculators saying it's a close match. 5th sub was a Memphis Mojo 10d2 bought with a custom box built same day, that lasted me a hold 4 months at normal listening levels before blowing out at random! At this point I measured the box myself and it was 0.10cf to small!
I got another Mojo for free as a replacement thanks to the shops mistake and this ones in a Bassworx box, sounds amazing, but at higher volume you can hear reverb from port and tuning not being correct.
Using my current Mojo (15-Mojo10d2) I'd like to have a custom box built correctly!
I have been messing around with many calculators and having bad luck getting the box shape I want.
If someone would please help me I grately appreciate it! I'm wanting a wide box with eather a bottom port or two side ports. I'm not sure if should just use round ports or go for slot to give the hole box better stability.
Box idea is for SPL or close to SQL, box roughly (Wide 22''-25'', Tall 13''-15", Depth 13''-15'') and will have a rear glass window with LED in the box.
Woofer displacement of 0.14cf (Cone/Mounting Hole 9.43'', Mounting Depth 7.5'', Xmax 0.625, Magnet Diameter 8'', Magnet Height 4")
SPL - 1.50cf 45Hz
SQL - 2.25cf 35Hz
ANY AND ALL HELP IS GREATLY APPRECIATED!
Needs this monster sub to last!!!
(Notes)
Stereo Deck - Pioneer: deh p5100ub
Mids/Highs - Pioneer D Series (running off Deck only)
Sub Amp - Alpine: MRP M500
Sub - Memphis: 15-MOJO10D2 (10")
Sub wired to 4ohm running at 300rms...
See, that wasn't so bad. I would change the thread name to ported enclosure help for 15" Mojo.
Also let us know what you are powering the sub with and what vehicle it is going in.
I can give a stab at it for you but there are others who are much better at this game than I am, like Joe X
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Notes added, and topic changed. Hopefully can get something made up, blowing out good subs is getting far to annoying and expensive!
Oh man, I think I misread that, lol, thought that sub was a 15 but it's a 10, right?
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Yes it's a 10'' the 15 is series number from the older line of Mojo's.
Right, what's it going in?
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
For now an overly beat up 07 corolla! but plan keeping it for my when get new car.
It would be much more feasible with a slot port to do a side port as with slot ports you don't want them to be much more narrow than 2", and it is harder to tune low with a slot port without using 3 common port walls, and to do so across the top or bottom of that small of a box 2" wide is damn near impossible.
Aeroport would be easier, and you could just double up the front baffle and add dowels for bracing to rigid up the box.
Here is my shot at a slot port with port on the side and sub/port facing same direction
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Ah, I asked cause if it was a hatchback or suv some people benefit from a sub up port back configuration, but for a trunk sub/port 1 direction works good
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
As for the glass on the back, unless you use 3/4" plexi glass I would say don't do it
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
