So I got a back up camera I'm installing and this is my first time doing it and my aux cord and a red cord coming out of both ends what are those for and what do I do with them and on my pioneer I got purple and white reverse gear signal input and i have no Idea where that goes either lol
Thanks for the help
lime green gets ran to the break wire idk what your talking about with the aux cables the way you worded it has confused me, i cant tell you how to do it without knowing which one you have, they are done differently
Idk the aux cord just has like a red wire coming out each end of the aux cord like looks like its connected to the the connectors of the aux cord
you need to take a picture of the connector it sounds like you bought the wrong camera
the connector you need for 90% of decks is
red to deck power black to ground yellow plugs in camera or r-cam spot. lime green to parking brake or parking break bypass. purple white need to be run to the reverse light ligh wire either found a fuse or at light bulb or in drivers kick pannel. if your lucky and your vehicle uses a pack module some pack modules have a reverse out
