Chance_P Posted August 3, 2013 Report Posted August 3, 2013 How's it going guys? This is my first time building an enclosure. I've always just used prefab boxes but have decided to gain some knowledge and put together a half way decent stereo system. Anyways, I figured I would post what I've been up to and see if any of you have any tips or comments. I messaged user Joe X out of the blue and asked him to design an enclosure for me since I don't feel confident in my own abilities and he was generous enough to do it for me. I gave him my max dimensions and what equipment I was using as well as what I wanted the box tuned to and he got back to me with some plans. Here is what I'm putting together. Enclosure Specifications:Fb = 34.5 HzVb = 8 ft^3External Height = 21 inExternal Width = 42 inExternal Depth = 25 in Port Width = 28 inPort Height = 4 1/2 in Tonight I was able to get the bottom and all four sides cut, glued, and screwed together. I used 1 5/8 drywall screws with square heads for assembly. Everything pre drilled and counter sunk. Tomorrow I will work on the baffles, port, and bracing. I have a couple of questions I'd like some opinions on. -Should I caulk or silicone the inside seams of the box? I was pretty liberal with the glue already. -What's the cheapest thing to coat the box in to keep moisture away from the wood? -Should I carpet the box or just sand/fill/paint the outside? Are there any advantages/disadvantages to either method? -Are there any tips or tricks in the assembly process that any of you have to offer that would make this particular box function or perform better? -What diameter should I cut the holes in the baffles? Sorry if any of these questions are n00b-ish. I just want to make sure I do everything the best way possible with this particular box. Thanks for reading guys.
Chance_P Posted August 6, 2013 Author Report Posted August 6, 2013 Quick question, do i put the port side or woofer side forward? Vehicle is a Jeep Cherokee.
zydrix Posted August 6, 2013 Report Posted August 6, 2013 I would use loctite 375 pro I believe it's called on the inside seams. ( never hurts) or could add some 45s to help with airflow an strengthen the box some. My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
Joe X Posted August 7, 2013 Report Posted August 7, 2013 Quick question, do i put the port side or woofer side forward? Vehicle is a Jeep Cherokee. The port goes near the rear gate, similar to a subs up/port back box.
