Voltage spikes when blipping the throttle?
Been doing some searching, and not actually found an answer to the voltage spikes.. however, I did find this.
I had a similar experience (with a Mercedes, however) and the Bosch mechanic told me that the diodes could have failed due to spikes caused by worn out rings/brushes to the alternator rotor. The brushes start to jump and this creates lots of spikes which can kill both the diodes and the regulator.
Which makes me wonder, if the new brushes aren't worn in yet, could this be the issue? and its just a matter of running it for a few days...
I had a query...
Since taking this pic, I've added a 0ga cable to the top alternator mounting bolt, and also removed the paper from the aluminium bar.
My question however, seeing as the rectifier is mounted to the rear housing, how exactly does the 320amps on the ground side make it to the front housing? There's no ground stud on the rear housing, and the only real connection between the two appears to be the four 4mm bolts? Plus the housing is painted, so who knows how good a connection this even makes?
  • 1 month later...
Mechman have told me that the voltage spikes is exactly what their alternators do, and that there's nothing wrong with it :shrug:
Not acceptable in my book
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
how many batteries? and also the ground situation is an interesting question
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Currently running two 1000cca, 130ah batteries in the back, and an XS D3100 (1100cca, 110ah or so)
So yes, they are mismatched. As well as a 750cca, 50ah battery under the hood.
(420ah?)
I've realized specifically when it happens.
Warm engine so the idle speed has dropped, but the alternator still hasn't suffered from heat soak, so its charging at 15volts, or close to it.
Sitting at lights, with the warm (low) idle, means the alternator has basically switched off. (car idles at about 560rpm although I have a 1 : 3.7 pulley ratio from memory)
When you accelerate, the alternator kicks in, voltage spike that's higher than when the alternator is warm, and the amp goes into protect.
  • Who's Online   0 Members, 0 Anonymous, 3465 Guests (See full list)
