any of you gents into, or knowledgeable in woodworking (specifically veneering)?
hey all, im wondering if any of you would have suggestions for adhering raw wood veneer to plastic? ive read epoxy would be my only decent choice, but im significantly concerned about the epoxy bleeding through, as the veneer im using is incredibly thin.
fyi: ive read contact adhesive such as weldwood wont work without severe risk of bubbling, or cracking!
Could you try both of those on small pieces and see if it works?
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Ya im just starting on woodworking ive always done it but never really in depth im just starting that so good luck man!
My setup,
Digital Designs M80
Kenwood x-696
SHCA 0 gauge
hmm.. thanks much for the suggestion big dee! titebond will adhere to plastic?
I think tite bond will adhere to pretty much everything if sanded correctly . Although I may be wrong
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
Straight from the titebond website :
"Will the HiPURformer adhesives work on plastics?
There are literally thousands of plastic materials available today. While the adhesive is effective in bonding most plastics, we recommend that you "test" a small area before you apply adhesive to the actual project. Roughing up the plastic surface may help ensure a stronger bond."
Team Subsonic Lows
My brother owns a cabinet manufacturing facility. When glueing laminate(plastic) to wood we always use contact adhesive. I would make sure the plastic is clean and sanded.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
