Ground Zero Bmw X5 40kw 6x15" NautiluzCreation
Now I finally have the time to create a UBL. There will be a lot more pictures in this thread. So if there is any question feel free to post them in my ordinary thread here: http://www.stevemeadedesigns.com/board/topic/156970-ground-zero-6-15-40kw-bmw-x5-nautiluz-creation/
This is my page on facebook: www.facebook.com/nautiluzcreation
And my youtube channel: http://www.youtube.com/user/Nautiluznet
Equipment used in the X5 are:
Headunit:
Ipad 4 64G
Prosessor:
Are going to use 2 processors when the front doors are finished.
Amps:
Speakers:
Battery:
8x 105amp AGM
Dampening:
9x Bulk Pack dynamat
9x Dynaliner
Kabels:
6x Stinger Expert RCA
40m Stinger Expert 50mm2
40m Ground Zero 50mm2
150m Ground Zero 4mm2
My car audio build page on facebook: www.facebook.com/nautiluzcreation Store: www.nzc.no
Skjermbilde%202015-11-23%20kl.%2022.39.3
Starting with the outside of the car. Only thing i have done here is to lower it by approx 60mm front and rear. Since it is equipped with original air suspension front and rear this is done by computer. And changed to silver/grey front grills and hood air intake. 20" original rims from 4.6is.
Windows are tinted and getting som Ground Zero stickers
Hood is getting some foil
How the car looks now.
Cars ready for a 3500 km road trip visiting Ground Zero headquarters in Münich Germany.
Now some dampening..
This is only a small part of dynamat that where used.
After several hours of disassembly
2 Layers of Dynamat Extreme
Nearly all original electric parts have been moved to other places in the car, black tanks are for the original air suspension.
553621_420560264663896_562811844_n_zpsc4
556_420560561330533_2124820970_n_zpsafee
Making a template for the sub enclosure.
229956_420560621330527_141277774_n_zpse6
530836_420560647997191_2130264844_n_zpsf
525953_420560764663846_617871345_n_zps52
Resin used on the carpet.
22290_420560847997171_1326775027_n_zps32
After several layers of fiberglass
409279_420561014663821_1504918023_n_zps2
Since this enclosure took me about 600 hours i'm happy that i built a steady construction to place it on.
Inn total this weighs 55kg, fiberglass construction is about 1" thick with 2 layers of sandwich. Topp is made of 38mm MDF
This is how the enclosure is being held into place. I am using the same brackets that originally holds the rear seat
Mounted a MDF plate that is going to be molded into the side wall of the box.
Added a thick carpet on the backside so that the enclosure have some clearance
Adjusting the top plate to get maximum volume.
Clearance is about 3mm to the rear window. Consider that the 40mm plexi is mounted on top of this plate.dec3s4kmmxtd1dqksc6k_zps6555609d.jpg
Top plate made to hold it all on place when molding the walls.
Carpet is attached to a separate MDF frame on the top of the lower part of the box
Attaching carpet to the top plate.
Resin is applied
Side walls dry and ready to be taken out of the car and get some more fiberglass and resin
Cut out the top plate so that it is possible to remove side panels
This is how it looks on the outside.
Side walls is made of 1" fiberglass with 2 layers of sandwich and weight is about 20 kg each.
This is how the puzzle is going to be assembled inside of the car, using 10mm bolts.
Holes for bolts holding the front plate.
Reinforcing wall for the plexiglass mounting.
Ready for "paint"
Nearly ready
Starting on the front plate 2x19mm MDF with 40mm plexiglass manholes for inspection and cleaning of enclosure.
40mm plexiglass
Glued 10mm MDF on to the plexiglass so that there was possible to attach the center tip og the router without making a hole in the glass.
After several runs with the router...
Steel frame that are going to hold the glass in place.
Marking where the holes should be
Sanded the plexi with 800 paper to get a frosted look.
20" rim seen through sanded glass.
This is where the speaker cables are going through the wall
Adjusting the size
This is 2 pcs of 3mm laser cut steel that is welded together. One with circular holes and one with hex holes. So that the cable bushings are held on one side.
There is a "angle iron" that reinforces side wall and bottom plate together.
After powder coating.
