New here and I hope I can find some help . I have a 2005 acura tl. Just installed a alpine type x 12" on a hifonics zrx3000.
I also have a dd-1 to use in tuning. I have hooked up several systems but always with new deck. My acura needs to keep the factory HU so I used a Line out converter. I wired into the factory 8" sub wires. I did some research and found the stock HU puts out a bad signal and or a tampered signal? Also read i would need some kind of processor to fix this or tap pre factory amp? or maybe its the rinky dink LOC i picked up from a local shop.
The dd1 picks up distortion at like level 10 of 40 with eq flat. then i tune the amp to that and it is too quite. Crank up the deck and amp level and it puts out some sound. I just want to make sure it is right and im not distorting my sub. But im confused.
anyone have any experience with the TL?
Thanks , Erik
You need to tap into the sub out put...
You just go willey nilley, you may tap into a signal, that is band passed that will make a low end want, no good.
Feel me?
Car audio systems these days, are "smart". To smart.. shit..
You need to find, and tap into a signal, that will allow you to get the band(s) you are looking for....
I love the Tl shape. Love it.... great lookin sedan... IMHO
(i had a TSX build that i loved, and NOW, wish i still had)
Good luck
Best case, is BEFORE the OEM amp,, just after the HU.
You want a signal, (you can search online for correct pin out) that is NOT band passed, or fucked with....... at least, not dicked with for what you want... (30hzish - 90hz ish) feel me?
And hell ya,.. lets see the ride.. Ive ALWAYS dug on a TL... yep..
this may help a lil bit:
2005 Acura TL Car Radio Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: White
Car Radio Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Blue
Car Stereo Antenna Trigger: Yellow/Green
Car Stereo Amp Trigger Wire: Red/Yellow
Car Stereo Amplifier Location: The factory amplifier is located in the driver kick panel (next to the glove box).
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Black
Right Front Speaker Negative Wire (-): Brown
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Red
Notes: The center channel speaker wires are green/white - blue/yellow. The subwoofer speaker wires are yellow/black - lt. green/red.
OP not sure if these are correct but this is definitly a start
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Hey where'd you find the wiring scheme at? I kinda wanna find something like that for my car
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
  • Who's Online   0 Members, 1 Anonymous, 927 Guests (See full list)
