" i like bein heard from blocks away i can be heard from 2 block away now wit my setup i have but im lookn for 6 or 7 blocks away which would b my best bet on accomplishing that?
With that , I'm out ...
"Walmart Where Car Audio Is Both Funny and Sad" "The weak are meat, and the strong do eat..."
Well as I said I put a 140.1db on the TL with my 1 on 1.2k the woofers can take 2k daily BUT you have to make sure it's clean uncliped power. Now if you do that and run 4krms you must have the electrical to support it. A high output alt is a must, plus several runs of 1/0 wire from the front to the back and then you will need batteries. I would say 5 should work but again I could be wrong on that. For the electrical you need it will cost more then the amps and subs. Just a fyi
Edit: now once again I will say this people may not bitch but still don't do it in public areas go to a place where no one is around to do what ever it is y'all think you are doing so cops don't get called.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
