voltage spike help help help basshead down
If your DMM reads steady and your volt meters are erratic I'd suspect there is a loose/pinched wire somewhere on the leads
Oh: and go out with a wrench and make sure all your connections are tight. That's not a bad idea regardless. Verify all fuses too
Checked wires fuses I was other trying to figure it out for about 4 hours and I gave up my thinking its that pcm bullshit thing were the car sets the h/o to run where it wants to where it set on the computer and I think that's why my gauge lights are on
Could you turn off the panic mode, take a step back, and type things out in detail? It's tough for me or anyone else to help when we are only getting partial information.
How are you measuring voltage when you say you are dropping to the high 12s?
What amps do you have?
Have you done the big 3?
Idle or revving?
Sorry I'm doing this on my phone I'm measuring voltage drop by my voltage reader on my car. For amps I have 2 AQ 2200s strapped the big 3 is also done. And for idle my car voltage is at 14.4 to 13.6 and revving about 14.4 to 14 without the system on my amps all turned off
  • Who's Online   0 Members, 0 Anonymous, 1584 Guests (See full list)
