audiofanaticz Posted August 29, 2013 Report Posted August 29, 2013 Id dont soak up as much as you think in mdf, soak just one side of mdf with resin, then make a fresh cut in the wood to expose how far it soaked in (not how far it ran off the sides). not much at all.. Better yet, poor some resin on a plastic bag, then remove the bag, and watch how easy the resin alone chips off in pieces effortless. Bill lolo just used that as an example and its a pretty damy good one. The dust sucks, I agree. But with a proper dust collector its not that bad when cutting it up, with a down draft table its not too bad when routering it, and if you use a respirator when routering it, it dont bother me one bit. With that said when your cutting out speaker holes or rounding over edges, any wood is going to throw up dust. it may not be as fine but its still getting tossed into the air, and your still having to clean up afterwords. My whole point with this thread is how Sky High acts like MDF is a inferior wood to what they call birch, maple, or cherry, when all it is they are using is plywood with a thin veneer of birch or maple on the top and bottom that adds no physical strength. Now that is inferior wood to real birch and mdf.. Might as well just use plywood and save your self that extra 10-20 bucks that is going down the drain. Perfect example, Mike singer, what are all his builds made from? straight up plywood, not no gimmick type wood that costs more for no reason but a thin veneer, but you dont see him talking the wood up like its something great when its not.
Hugh G. Rection Posted September 8, 2013 Report Posted September 8, 2013 So, on facebook you posted a box you were building, and on the comment i asked why not MDF and you said you dont use MDF at sky high, why is that? are those drywall screws? seriously? Owner of BigAss Ports
AA98hoe Posted September 8, 2013 Report Posted September 8, 2013 Alot of hate goin on here.. One question ? Who's louder? TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
