UBL: Lbox88's 2009 Equinox
Started on the last door. It is too damn hot, so I've been working on it at night but it's still too hot lol.
(temp is close but it does not measure humidity, which is VERY high)
Half hour later
And that's all I could stand to do tonight. It'll cool off this weekend, so I should be able to get it done faster then.
Worked on the last driver door a lil bit. Been busy with things around the house while I had vacation time off.
Was working on putting the mid in the ring adapter I made, and then this happened :jon:
More to come tomorrow hopefully.
Wired up. Got the charger on the car now to bring all batts up and make them the same.
Was a Biiiiiiiiitch moving this 80lb bastard back here
1/0 is both crimped and soldered.
Got a PAC SNI-1. found a shop by me actually carries almost all things PAC :) no more alt whine now
Cleaned up the wiring a lil bit in the back
Then ghetto mounted my volt meter. I don't expect this thing to be in for more than a month or two, so I didn't want to cut/drill holes for such a short time.
Gettin' that float voltage up :)
Now to see if the VM hangs on after a few days of beating on it.
So I see 3 things I still have to work on that aren't too bad. Deaden roof, run big 3, and run new remote wire. I have leftover Damp Pro I need to measure and see how much I have left vs. how much I need to cover. Do not want to pull the headliner only to find out I will only have 50% coverage. So I took a look at doing the big 3 and it is going to be a tiiiiiiiiight squeeze do to the shitty ass battery box the batt sits in.
Since I added the last battery, I have been putting my charger on nightly to make sure I have a good charge each day and don't stress my alt too bad.
Made some new labels for my 4 channel wiring. All I got for right now lol, might work on something a little bit later but it's hot as fawk out and humid to match right now.
Labels before
Labels after
*sigh* I also have my old sub RCA's and the new 4chan RCA's I was initially planning on using along with some wire for a new remote. I will get to it at some point, just procrastinating like none other because I don't want to tear the HU and dash back apart.
Rough calculations show I have roughly 3500 in2 to cover on my roof, and I have roughly 3100 in2 of Damp Pro left. Blah, needs to cool down and I need time off work so I can get some of these smaller things done.
Did it, I flew through the car last night, replaced all the RCA's with new ones, ran a new remote wire and wired the VM up with a Relay so it turns on with the HU now. I didn't take any pics last night as I was just trying to get it done. Turns out the alt whine I had is still there, so the SNI-1 went back on. Glued the VM back down tonight, put a trim piece back on, and hooked up my big charger tonight though. Floats a wee bit higher than the BTP, just want to make sure it gets a good charge tonight.
Old RCA's in the parts/junk drawer just in case something were to happen
