load350z Posted August 22, 2013 Report Posted August 22, 2013 I have 2 t1 12s in a slot ported enclosure. Rockford box advisor says 1.75 cu. ft per sub. 1 port Diameter of port 4 in. length 9 inches long (tube port) what will this convert to in slot port? 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 Pic of the enclosure its in now. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 I will have to get measurement of the port later.. I think the port is wrong 2 inches wide I think it 15-16 inches height cant remember the depth but the box suppose to be tuned to 35hz. Is this correct? 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Joe X Posted August 22, 2013 Report Posted August 22, 2013 Impossible to know the tuning without area and length of the port, anyways what's the complaint?
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 Hey joe x the guy I was hoping to talk to. I seen a few of the box designed u did for other people on here and ur port design used a 4inch port. I was comparing ur design to my enclosure and my port seems like it maybe to small. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 I think the depth of my port is 9inches. I will double check once I get off work in a hr. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Joe X Posted August 22, 2013 Report Posted August 22, 2013 The width of the port is not directly important but the area and height to width ratio, that port looks thin and overall area seems small, I was wondering if it sounds bad, have port noise? weak low end?
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 The enclosure is a lil over 4cuft total without accounting the port area n speaker displacement. I had to get it built that shape so I would have space in trunk for a stroller or etc.. plus so the enclosure will slide all the back to the back seats The altima has a funny lip in the trunk. It actually sounds pretty gud but the low end isnt all that great in my opinion. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
bbeljefe Posted August 22, 2013 Report Posted August 22, 2013 That port looks to be about 1.5"x15" or close to it, which makes it about 22.5 in². A 4" port is 12.56 in², so for two woofers it should be 25.12 in², according to Fosgate. But for higher power you should probably have ~50 in² of port for two woofers in 3.5 cubes. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
load350z Posted August 22, 2013 Author Report Posted August 22, 2013 Powered by a rockford T1500bdcp 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
