john253a Posted August 24, 2013 Report Posted August 24, 2013 Hard to say unless you lission to them next to each other Do I like the t2 no Idd take the t1 over t2 But t3 over them both And t5 over all above But it's not my system it yours You really need to go into some shops or cars and lesion to some setup If you not competing in sq then it all personal taste And you'll get more sq out of matting you doors then buying a better speaker and throwing in an unmatted door There's more to sq then people think You need to start with the signal so a good head unit Then RCA's some decent ones not Walmart ones Amp cables and then speakers Its No good having 1 high end and entry level everywhere else as you won't get the most out your system
José Gozaine Posted August 24, 2013 Author Report Posted August 24, 2013 I have $ 400 I want to buy two speakers or one how many would you suggest? I have to fear that my subwoofer attenuate my speakers I appreciate your suggestions my sistems 029 por Goz@ine, en Flickr
genesis Posted August 24, 2013 Report Posted August 24, 2013 Yes go with JBL for same price range. Focals are not that great at the price range of speaker and Morels are still my pic. I disagree. ive ran focal for years with great success in the lanes. morels are ok, rainbow is a better choice. the jbls are "decent", but its REALLY going to depend on your install (no matter the speaker)
genesis Posted August 24, 2013 Report Posted August 24, 2013 what's your power range? do you like metal dome or soft dome tweets?
José Gozaine Posted August 24, 2013 Author Report Posted August 24, 2013 what's your power range? do you like metal dome or soft dome tweets? my rango is a amplifier MB QUART onx 4 chanel . 125 rms 1000rms I've heard Focal Access 690 CA1 6 X 9 with twester of metal I will want listen with soft dome tweets
john253a Posted August 25, 2013 Report Posted August 25, 2013 You'll get the rainbow slc 2 or 3ways for under 400 And being a 2ohm final comp set they'll make the most out of that amp
José Gozaine Posted August 25, 2013 Author Report Posted August 25, 2013 You'll get the rainbow slc 2 or 3ways for under 400 And being a 2ohm final comp set they'll make the most out of that amp how many should I buy? a pair or two pairs? that model suggest?
KMS Posted August 25, 2013 Report Posted August 25, 2013 I've had the Morel Maximo 6.5's. They're very very nice speakers for the price of $140 I paid. However, there is no tweeter level adjustments, nor is there a flush tweeter mount. Luckily my golf had stock tweeter locations on the dash with a cover over them and fit fine. Other than that, I loved them. I now have the JBL MS-62C which I paid $175 for. If the Morels were able to be flush mounted and had a tweeter level adjustment and ran for the same price and I had the option to choose between the two. The Morels would be my pick. More midbass, warmer tweeter due to the silk dome, the JBL uses a metal dome. I had problems with the build quality on the MS-62c with the solder not touching the lead on the terminal so I had to add some more solder. Probably just mine as I haven't seen others with this problem. I would love to hear the Morel Tempo's though. I seen there are some Tempo sets going for $200 or so on ebay. Not sure if real or fakes, again though. No flush mount tweeter options. If you have a place to put them I'd recommend the Morel set even though I haven't heard the Tempo's as the Maximos were excellent to me. Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT
john253a Posted August 25, 2013 Report Posted August 25, 2013 http://www.woofersetc.com/c-10-compon-speakers.aspx?manufacturerid=125&minprice=0&maxprice=99999&=&pagenum=2& The tempo is flush mount now http://www.woofersetc.com/c-10-compon-speakers.aspx?manufacturerid=106&minprice=0&maxprice=99999&
genesis Posted August 25, 2013 Report Posted August 25, 2013 You'll get the rainbow slc 2 or 3ways for under 400 And being a 2ohm final comp set they'll make the most out of that amp love this answer!
