95 Yukon Wall design for 4 15's (Enclosure gods HELP PLEASE)
Slim337
I'm completely rebuilding my 95 yukon, from the ground up. Motor, trans, interior, paint, music & all. I'm going to put 4 Planet Audio BB215d 15's in a wall behind the back seats. I've taken the bench seat out & put 2 captain seats in the back. So I want a wall with a center port. I don't know much a bout tuning or any of that. It going to be a daily driver, but I do the occasional competition. I listen to mostly rap & r&b. I just like it low & LOUD!!!
My max dimensions:
Width: 4ft
Height: 3ft
Depth: 2 - 2 1/2ft.
Sub specs:
Power Handling (Peak) 3000W , Power Handling (Contin.) 1500W , Freq. Response 12Hz- 350Hz , Efficiency (1 Watt/1 Meter) 97Db , Impedance Dual 4 Ohm , Magnet Structure 240 Oz. , Voice Coil Former 3-Inch , Mounting Depth 8-13/16-Inch
Diecast Aluminum Basket Non-Pressed Paper Cone 7-Layer High Density, Fat Rolled Foam Surround Dual Flat Spiders With Woven Tinsel Leads
Black Anodized Aluminum Voice Coil Former Insulated Lead Wires Exclusive Para-Term Connection System
15-Inch Dual Voice Coil Subwoofer
Highs & Mids:
(4) Fosgate T1 3way 6x9's
(6) Fosgate T1 6 1/2's
Power supply:
(2) Fosgate T1 1500bd's
(2) Fosgate T1 600bd's
220 amp alternator
(2) kenetic 1200 amp batteries
(1) yellow top optima battery
Thx ahead of time for any help given.
It's a 95 yukon. There's a complete list of all the equipment I have, with max diamentions. I don't know much about tuning. But what I'm looking for is a wall design for 4 15's with a center port. The sub specs are also listed. I just like it loud & able to get pretty low.
Thx for any help you can give me.
The vehicle isn't in front of any of us. Getting a free design on a wall, without a vehicle that we can go out and put our hands on, is a TALL order dude. I know this is a blunt response, but I'm not surprised that you don't have a design yet.
A wall will require a Shell to be made FIRST. It's pretty easy to just give you an idea of dimensions and port size, but no idea if you can fit those dimensions by the time you get your shell built. You'll then need room for wire, amps, batteries, etc. So dimensions we I'll be difficult to provide, while still allowing for the unknowns.
Some other unknowns are the actual sub specs. Power handling and sensitivity aren't indicators of what the sub is all about. How about VAS, Qes, Qts, Xmax, and Bl. How about ALL the sub specs you can gather and then pairing them here as well as the recommended enclosure size for ported from manufacturer.
First off, I want to say thx for the help. It's a 4 door Yukon. I'll have to find the rest of the sub spec's. What I'm lookin for is basically a center slot ported box built to the posted max diamentions. I'll then build face plates to be attached on front & back with all my angles to close off the rest of the space. And with the posted max diamentions I've left room for amps & batteries.
Most walls
Get roughly worked out first
For estimate on port size and tune
Then as you start boxing it you, you have to adjust it on the fly
What idd do is a drawing of the front and rear and make it out of cardboard,
Then you can work out the surface area and then the volume once you no the depth slowing a good 8" at the back for battery's amp and wires
Idd like to see 3x 8" aeros or even 2x 10"
With that style seats
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
