So I had to get new tail-lights due to the fact that blacked out tail-lights are illegal in North Carolina blah blah. So I got black euro style tail-lights.
Old Lights
1236993_729836307030046_1167148671_n_zps
New Lights
1175435_729836093696734_1387481743_n_zps
1186293_729836230363387_1460872840_n_zps
So my sub box is flexing still in the center of the top baffle that is 1" thick..... It has over 2 layers of fiberglass supporting it and bed lined on top of that..... I also have a 1"x1" solid oak support running front to back of the box holding the front baffle in place.... I think its time to add another 3/4" to the baffle to strengthen it....
Hopefully that helps....
Any IDEAS....
More bracing! Add a support from top to bottom if possible. That might even make it so you don't need another baffle.
1993 Suburban
6 Crossfire XT3 15s
Crossfire XS-16k
Crossfire mids & highs and amps
65ah Cmax bank
Iraggi 320a and Mechman 300a
cant due to port placement and where the subs are mounted......
  • 4 weeks later...
Major update's....
So I pretty much took apart the sub box and reinforced everything.... 3 layers of fiberglass.... and braced the inside seams with 1"x1" birch..
New box size is about 5.5cuft tuned to around 29ish hertz....
The front of the sub box is 1.5" thick mdf and birch and the top baffle is 2.5'thick birch and everything is hex bolted into place....
Getting ready for the bolt's
Bolt's in
Big 45hz port lol
Getting there...
Bolt on front panels....
Another baffle....lol this thing is gonna be indestructible...
Sub's inverted....
sexiness with the 29hz port ( not finalized yet)
Finished pic...
dude? that port though.
I have 3 different ports a 45 hertz port that is 10x8 a 35 hertz port that is 10x5.5 and a 29 hz port that is 6.25x6.25"
i think you are a little misunderstood as far as box tuning goes. you can only shrink your port so much to get a lower tuning. generally you will want a decent sized port, but make it LONGER to lower tuning. right now your at around 5.5sq inches of port per cube, which is way too small.. People tend to think the "port per cube" rule of thumb is garbage, but its just a rule of thumb. CAR AUDIO COMPANIES such as Fi and Sundown recommend a starting point of around 12-14sq inches of port per cube for a daily tune. I've went as low as 10 per with great results. I hope this helps.
TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET
150Db Club
160Db club in the future
I see krakin as a threat
I under-stand this completely this was meant to test what that port tuning would do in my vehicle..... the port is not finalized at this time... thankyou for the advice though...
  • Who's Online   0 Members, 0 Anonymous, 2953 Guests (See full list)
