Nice work on the box, the port and especially that trim panel. Looks like it performs really solid with just 1K.
Thanks Man still working on doing as much as I can to gain on my daily port on another note I can do a 145 at 29hz lol it got a little windy in the liberty.
efficient box for sure! keep it up man
New Update Purchased a DDM2B i wonder what this bad boy is gonna do for my score lol
More recent sub box photo..... i think Its time to increase the port size again maybe I will gain a little more efficiency...
Nasty amp for sure, i've clamped close to 2500 watts on a good electrical, are you wired at 1 ohm?
On the rf bd 1000 I was wired to 1/2 ohm on the DD I plan on doing the same thing hopefully I can pull off a 150. Also I am thinking of puling my subs and rounding over the inside bottom edge of the hole cut-out hopefully I gain a little. But when I bought this amp it was pretty heavy for what it is hopefully I can pull off close to 2.5k with that amp. Might need to get some Copper amp inputs.
Thats already tested on my spl gains topic, that should give you a .2 dbs gain at the most, try rounding over the port also, internally and externally, i see a full db gain right there ;)
Im pretty happy with this box the response is amazing also when I did testing it did a 145.6@ 29hz outlaw. But I did read a lot from the spl gains topic I was kind of impressed at how much more efficient I got this box from before.... I wonder If doing door panels front and rear fully fiber-glassed would improve my score.
No clue, my doors are almost stock, only have a 8" mid on each door using some pods, step by step man, once again, biggest gain will be the port itself, just use some 1" pvc on the internally and externally, that and the m2 would get you over 149 already
  • Who's Online   0 Members, 0 Anonymous, 2656 Guests (See full list)
