DylanBunch Posted August 30, 2013 Report Share Posted August 30, 2013 So im looking to do a 4th order with 2 18s at the c pillar and i want it to be a good low end demo car while not loosing the high end so i figure why not give a 4th order a try. Now im deciding between x 18s and zv3 18s. I have about 21cbft to work with and im aiming for atleast a 2:1 ratio, but with the x 18s having a suggested sealed side of 4cbft per woofer, i cant do a 2:1 with suggested specs and with zv3s having a suggested sealed volume of 3cbft per woofer itd obviously be a lot easy to get atleast a 2:1 ratio. Heres where i run into trouble...... even with a sealed side 1cbft less than it needs to be, the X 18s play lower, higher and peak louder according to winisd. The have an low end f3 of 25 and a high end f3 of 80, while the zv3 18s are at 29-70. Also the X 18 peak frequency is 1.8db higher ( not that thats a big difference). Even though it seems like theyll play better, should i not put the X 18s in too small of a box? Also, im pretty set on doing a 4th order Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
STEALTH808 Posted August 30, 2013 Report Share Posted August 30, 2013 im no expert but i would give them at least 3 cubes per sealed. Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
STEALTH808 Posted August 30, 2013 Report Share Posted August 30, 2013 or do 2.5 and stuff a couple pounds of polyfil. Quote TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat Link to comment Share on other sites More sharing options...
DylanBunch Posted August 30, 2013 Author Report Share Posted August 30, 2013 my question is more about which sub to use Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
N9neMillahhh Posted August 30, 2013 Report Share Posted August 30, 2013 Zv4s all day!!! ;D Quote 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
Skullz Posted August 30, 2013 Report Share Posted August 30, 2013 Any sub will do what you need, just pick any brand you like and get what you need. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
DylanBunch Posted August 30, 2013 Author Report Share Posted August 30, 2013 Any sub will do what you need, just pick any brand you like and get what you need. So dont listen to winisd? Id be pretty bummed if i spent the money on zv3s and time and money a 4th order wall and them not play as well as the X's or the other way around Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
N9neMillahhh Posted August 30, 2013 Report Share Posted August 30, 2013 I wouldn't go that far and say that...from experience, I had one box that I had an RE, a kicker, a Rockford (current), and an HDC3, and they all performed differently, RE was best at lows but was also punchy, kicker was better at higher bass notes and got louder than I expected, AQ was the loudest but didn't get low enough and it was peaky, and the Rockford has the flattest response, gets decently low, and is decently loud, just has the best quality, so you gotta narrow it down a little more than "any sub will work for what you want it to if you do it right" cause you can tune your box to 24Hz just so you can hit lows but then you could get peakiness or it could be terrible at everything except 24Hz. You never know until you do it and try it, then play around with it and then you will ind what you like. Oh and Dylan I got a surprise for you! Quote 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
DylanBunch Posted August 30, 2013 Author Report Share Posted August 30, 2013 I wouldn't go that far and say that...from experience, I had one box that I had an RE, a kicker, a Rockford (current), and an HDC3, and they all performed differently, RE was best at lows but was also punchy, kicker was better at higher bass notes and got louder than I expected, AQ was the loudest but didn't get low enough and it was peaky, and the Rockford has the flattest response, gets decently low, and is decently loud, just has the best quality, so you gotta narrow it down a little more than "any sub will work for what you want it to if you do it right" cause you can tune your box to 24Hz just so you can hit lows but then you could get peakiness or it could be terrible at everything except 24Hz. You never know until you do it and try it, then play around with it and then you will ind what you like. Oh and Dylan I got a surprise for you! Yeah i fell the same way about what he said, seemed kinda sketchy no offense skullz, but idk im probably gonna have bassheads ent design the 4th order for me and ill probably do the zv3s so i can add power later if i want. But whats this surprise you speak of? Youve got me excited Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
Skullz Posted August 30, 2013 Report Share Posted August 30, 2013 I simply meant that there are no 4th, 6th or any order subs out there. There are ported and sealed spec'ed subs, either they have an extra stiff suspension for sealed applications or suspensions tuned for porting. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
