soundstream15 Posted August 31, 2013 Report Posted August 31, 2013 so i replaced my stock alternator with a mechman 170amp, im running a crunch GP3000d pro, with my stock alternator i was holding 11.8v now that i replaced it im holding 12.2 and for 320$ just for that little few volts it wasnt worth it, but was having some belt slipping since belt was a little to big, my alt has a smaller pulley so did that today. to me, i thought i would see a difference but did not. i am not sure if my amp is just that power hungry or what, i have the big 3, more like big 5. running all 1/0awg wiring, dual inputs in amp. yellow top under hood and kitneik hc2400 in the back.i want to say its my amp being power hungry and yes all wiring is correct and ground n shit.
Jessica Posted August 31, 2013 Report Posted August 31, 2013 That seems weird. do you have any other amps? Sure you aren't clipping to hell and back? is your 1/0 ofc or CCA? 1 run or more? I have my stock 65a and two g34 deka's and two sk1500's and a 85.4 and drop to 12.6 or 12.4 full tilt. Not trying to brag, just a comparison. Doesn't mean much cause of box rise and stuff but just thought i would throw that out there Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Jessica Posted August 31, 2013 Report Posted August 31, 2013 Oh, what is your charging voltage with everything off? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
soundstream15 Posted August 31, 2013 Author Report Posted August 31, 2013 no, no clipping, i set with DD1 -10db track everything is OFC resting is 12.7 with car off
soundstream15 Posted August 31, 2013 Author Report Posted August 31, 2013 no, no clipping, i set with DD1 -10db track everything is OFC resting is 12.7 with car off 1 amp btw
Jessica Posted August 31, 2013 Report Posted August 31, 2013 I mean, what do you charge at car running with nothing on. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
tacomaguy1 Posted August 31, 2013 Report Posted August 31, 2013 Car charging voltage, not resting batt voltage Amp is wired to?(ohm load) Team Flex Issues
tacomaguy1 Posted August 31, 2013 Report Posted August 31, 2013 I'd want more battery, those amps weren't very efficient Team Flex Issues
soundstream15 Posted August 31, 2013 Author Report Posted August 31, 2013 oh ok, well when i installed my alt i tested with everything off it was 14.7 and when i turned everything on it was 14.5 1ohm
soundstream15 Posted August 31, 2013 Author Report Posted August 31, 2013 we can use this as an example AQ2200 that i had, sold for this, wish i wouldnt of. with stock alt, lowest i dropped to was 12.6
