well im gettin my door speakers today and im not sure how to take the door pannels off my truck, yea yea i could go look.. but im sure one of you out there has to know and could save me some time and headache, so its a 04 f-150 fx4 supercab.. i got components for the front 2 and the back 2 doors, so yea i just need to take the panels off
ill take build pix, but wont post them till i get all my stuff, so keep on waiting, lol
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
have u ever taken off a door panel b4?
Eclipse cd7000
Assuming you have power windows...here it goes...
Pry off the speaker cover
Remove the speaker
on door handle there is a small access plate...remove and remove the screws
same on the power window module
2 screws on the bottom of the door
I believe there are also 2 underneath the armrest
grab the door and lift up and out..the clips you see are not clips but alligning brackets used for setting and holding the door panel inplace so you can screw it on.
Have fun!
A tip when re-installing the panel. Remove the 2 lower white clips that the lower screws for the speaker attach 2. They make it difficult to align and slide the door panel down, when re-installing the panel. I cracked my door panel re-installing it. Once I removed those clips it went right on.
p.s. i took this from a web site so its not "my" instructions...link to the ford forum topic = here
Eclipse cd7000
Remove the speaker
Have fun!
i didnt know the speaker cover came off, if that comes off, do i have to take the hole door pannel off if that comes off? im just replacing speakers atm
My F-150 Build
no i dont think u have to remove the whole thing..but i took that from a web site...the second step to the instructions says remove the speaker so im assuming u DONT have to remove the whole door...
Eclipse cd7000
that will save time, thanks
My F-150 Build
