Bassgenerator Posted September 2, 2013 Report Posted September 2, 2013 I have a rockford t1500 and I want to daisy chain to my rockford t400 using all 4 channels. How do I pass through to the 400 without having to use another 2 sets of rcas to my head unit?
kickass audio Posted September 2, 2013 Report Posted September 2, 2013 you need to get 2 male to two female rca splitters like this: http://www.sonicelectronix.com/item_11702_Hitron-RCAY1M.html or you can get 2 female to 2 male rca splitters like this: http://www.sonicelectronix.com/item_16510_Rockford-Fosgate-RFIY-1F.html Then you will need to get 2 short runs of rca cable that will be long enough to go between your 1500 and 400 amp. If you choose to get the first style RCA that has one end as a single male connection and the other end as 2 female rca connectors you will hook it up so that you have the one male connector going to one of the pass-thru rca's on your t1500 (make sure you make note of which one is left and right so you don't mix them up when you connect it to your t400 amp). Then with the y adapter connected you will take one of the male rca connectors and plug it into the t400 so that it matches the side you connected the y adapter to. For example if the y adapter was connected to the left output on the amp, you will connect both the rca connections to the left inputs on the t400. Once you do this you just need to tune the amp and hook up your speakers and be done. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
