Complete noob recone question
Cox
What do I do with these leads. Do I splice them or do they just untuck from under there. I was scared to pull on it lol
D976EFEF-D2A8-4BDA-BE24-A1D3124A8427-376
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
Pretty confused because they don't look anything like my old ones
0729BB11-9304-438C-B95B-FA1072E37DD5-376
Mechman 240a alt
Looks like you ripped the piece where you supposed to solder them to. if you take the black shrink off then you may see where its soldered together. But those leads are to go in just as is.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
which lead looks ripped? the old one?
Mechman 240a alt
Yes the old one. On my Fi I unsoldered where its connected to the basket terminals. I had to remove all the solder in order to push through the new leads. Like putting string through a needle.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
No Big Three yet!
you just solder to the bend in the loop. On the push terminal where there is the little hole, clip it on one side, bend it open a bit, slide the loops on, bend it back, hit it with a good amount of solder and done.
just unscrewed on the old one
Mechman 240a alt
Remove the black heat shrink from old leads. Then unsolder the wire leads from the metal pins its connected to. Screw back on metal pieces to basket terminals. Solder on new leads to the terminals that you screwed back on. and this after you glued your recone back in place on the basket. Make sure leads are lined up with the terminals.
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
No Big Three yet!
  • Who's Online   0 Members, 0 Anonymous, 1128 Guests (See full list)
