Shadow_80613 Posted September 6, 2013 Report Posted September 6, 2013 Okay so I have a xs s3400 in a Tahoe under the hood and I want to put a xs d3100 in the back to power a AQ 3500.1 my question is when I run the power wire from the s3400 up front to the d3100 In the back I know I'm suppose to fuse the wire on both sides what size of fuses should I use? Also should I run 2 sets of 0 gauge to the d3100 or just one? Since my AQ 3500.1 has dual power inputs and grounds and if I run two what size fuses should they be? Sort of new to this but with a little helpful tips I can manage so let me know please. Thanks also the altornators going to be upgrades to a 270 amp one.
Tarball Posted September 7, 2013 Report Posted September 7, 2013 2 runs front bat to back bat - fuse to the wire. Quality OFC 0 should be able to handle 300a. Same on you bat to amp - 300a per input. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Shadow_80613 Posted September 10, 2013 Author Report Posted September 10, 2013 So would i put a 300a fuse on both ends of the wire or 150a on one end and 150a on the other end?
AMI CUSTOMS Posted September 11, 2013 Report Posted September 11, 2013 300 amp fuse at both ends, two power runs would be best but 1 will do the job. Do 200 amp fuse for each input power for the amp. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
