Ground Zero GZNA 1.2500DXII question!
Bass_Maniak
Greetings to all. Who can say about the amplifier Grund Zero GZNA 1.2500DXII, along
the power level he with M3a, skar 2500, saz 2500. on the domestic one and the same with the saz 2500. if the owners of these amps here?
To less European´s here. I think it´s like you said those amp´s come often out of the same Corean buildhouse.
that is, you believe that they are assembled at the same plant?
It doesn't matter if they are assembled at the same plant or not.
They won't perform the same at all because they use different parts.
Ground zero makes good subwoofers but the amps aren't that good, but still decent quality and will put out enough power.
At sunset audio ask for more money to the amplifier at the same power to Ground Zero, but the power and reliability in the Ground Zero better. In the two bridges gzna 1.2500dxii shot at 0.25. but sundown audio hardly so in the low ohm can.
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
