subsonic filter
ham4864
box is tuned to 32hz is 25-27 a good number to set the subsonic filter to ?
or is there a test tone way. see there are many ways to do it
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Play some 40hz to 20hz sweeps and adjust as needed.
It's tough to give specific numbers for a SSF because unless you have a cc-1 or something, you can't set it accurately. Plus a lot of boxes aren't tuned to exactly 35. It's like +/- 3-4hz. And every install is different. So there's that to consider too
Turn up your subsonic filter a bit higher than you think you'll need to. Play a sweep full tilt. If the sub is moving too much when the sweep drops down, turn it up. If it has more to give, turn it down
Thanks that was some very good info and scary at the same time while doing the test. Man it looked the sub was out to jump out.
2009 bmw 5 series
Head Unit Stock
yes same sub in sig, In the book it says my xmax is 24mm.
2009 bmw 5 series
Head Unit Stock
Yeah mine is 28mm and its an 18! On the website it says yours is 26mm I wonder if they changed it? http://www.incriminatoraudio.com/li.htm I almost bought one of their Death Penalty series but decided that If I buy an Incriminator one day I will get one of their 21s to mess around with. Those things are huge man. It will probably have to be something for my house.
I've always wanted to try launching some ping pong balls with it or something. I just tried to look that up on youtube to see if anyone else had done it and found this haha
nice,what sub/s are you running?
If i get this jeep ill move up to some 15's or 1 18'
2009 bmw 5 series
Head Unit Stock
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
