bdog Posted September 17, 2013 Report Posted September 17, 2013 Ok, so looks like all i realy need is the speed controller and a AVBM. And yes i know a 12 volt charges at 14, actualy mine charges at 14.4 volts. But i want to run a 14 volt batt, wich will charge at 16.4 volts. This will eliminate the need for all the extra batts, cables, etc. since i have a single cab pickup and run only 2 amps. 1-400 watt rms and 1-1200 watt rms. The main 14 volt batt, putting out around 16 volts should be sufficent enough to run the 2 amps. No this is not correct. Just because you are running a higher voltage doesnt mean that it will support your amp better. ^^^ correct current/ amperage is more important than voltage. Its better to run at 12 volts with lots of current then to run 14/16 with a lack of current. Quote REP
