berard_ty Posted September 21, 2013 Report Posted September 21, 2013 I just bought this amp to push 2 21 inch dp's . Only problem is that I don't have the owner manual so I can't find max volts it can handle and I can post a link to the actual amp itself. From what I herd the amp is legit on power and rated rms . At 13.9 its rated for 6k @1 ohm . I was wondering if I can run it 15.3 volts . I have a 09 black ford f250 4 door black 4x4 powerstroke . I will post pics of the build on a different thread .
berard_ty Posted September 21, 2013 Author Report Posted September 21, 2013 Also I'm going from 2 powerbass 3xl 15s to a walled 21 dps . Should this be enough watts to make these speakers shitttt. I'm a run the speakers seriesed at 1 ohm load total for as much rms I can get at 1 omh . Also can d1 dp.21s handle being.wired at 1/2 ohm
gattiboy13 Posted September 21, 2013 Report Posted September 21, 2013 Just contact them personally...they are very cool and great with customer service there. cadencesound.com
Watch the bass Posted September 22, 2013 Report Posted September 22, 2013 Did you have the newer version with max input voltage 9 volt´s or the older for 6 volt´s? "in the abundance of water, the fool is thirsty" Bob Marley
