zack_e89 Posted September 25, 2013 Report Posted September 25, 2013 Ok so I've tried to do my research and this is what (I think) I've figured out so far: -I believe CJ mentioned using this material http://www.discountsteel.com/items/6061_Aluminum_Flat_Bar.cfm -I want to make one pair for 4 D3100s which are ~7 inches wide a piece, so they would need to be ~30 in long -Need a pair for a D3400 under the hood, so ~7" long a piece What I'm not sure of: -How thick and wide should I go? Is 1/4" by 4" close? -Am I getting the right idea here? http://www.discountsteel.com/items/6061_Aluminum_Flat_Bar.cfm?item_id=133&size_no=28&pieceLength=cut&len_ft=2&len_in=0&len_fraction=0&pieceCutType=12|1&itemComments=&qty=1 -Would I be able to do this all with a drill? I think I would just need to buy the bolts and use the correct bit accordingly? Thanks for any advice. 97 Suburban 8 custom PSI Platform 3 18's
rockFord_Expedition Posted September 25, 2013 Report Posted September 25, 2013 A drill press would be ideal but a regular drill could get the job done. Make sure you thread the holes for best results. Just be safe and have fun, that's what it's all about. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
TRON Posted September 25, 2013 Report Posted September 25, 2013 For tapping the right hole size, lets say 5/16, you should drill a 9/32'' hole to get 50% thread lock (the space between the thread in the bolt and hole). Basically if you drill a 5/16'' hole, you wont be able to tap it to 5/16'' Id also use stainless hardware with 6061 aluminum. Edit: Tapping chart: http://www.physics.ncsu.edu/pearl/Tap_Drill_Chart.html Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
zack_e89 Posted September 25, 2013 Author Report Posted September 25, 2013 Thanks for the help guys! For tapping the right hole size, lets say 5/16, you should drill a 9/32'' hole to get 50% thread lock (the space between the thread in the bolt and hole). Basically if you drill a 5/16'' hole, you wont be able to tap it to 5/16'' Id also use stainless hardware with 6061 aluminum. Edit: Tapping chart: http://www.physics.ncsu.edu/pearl/Tap_Drill_Chart.html Thanks for the info and the chart, that really helps! Maybe that should be stickied somewhere? haha Edit: Would this work well? http://www.ebay.com/itm/1-4-x-6-6061-T6511-Aluminum-Flat-Bar-x-36-Long-250-x-6-6061-Flat-/150720962692?pt=LH_DefaultDomain_0&hash=item2317ab6084 97 Suburban 8 custom PSI Platform 3 18's
