evermaxx Posted September 27, 2013 Report Posted September 27, 2013 Okay, so I tore everything out.. Had big 3 and one power run done in Knu 1/0 CCA. Looking to do SHCA wire. I'll have 1 d6500 up front, and two HC1400 in the back. I'm stuck on getting the 1/0 or the 2/0.. Also what all would I need? Btw I'm running a 2200 AQ & will be getting a 600-1000w 4 channel amp. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
CJ18 Posted September 27, 2013 Report Posted September 27, 2013 What size Alternator do you have? 1/0 will probably be plenty, but 2/0 cant hurt. Also I would highly recommend going with an OFC package instead of the CCA.
evermaxx Posted September 27, 2013 Author Report Posted September 27, 2013 Stock for right now. Going with mech man for Christmas - would the ofc be better than the 2/0? I know they say OFC is better than CCA Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
evermaxx Posted September 27, 2013 Author Report Posted September 27, 2013 Stock is 136a btw Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
evermaxx Posted September 29, 2013 Author Report Posted September 29, 2013 Bump for the rest of questions Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
ghostlyrich Posted September 29, 2013 Report Posted September 29, 2013 from what im reading from your post 0/2 should be more than enough and leave room for expansion. batts i would match then battery isolatory relay, battery volt meters for each bat if you want to make sure there working properly, battery guards if you want, count how many terminals you will need,quality rca's. damplifier, fatmat or dynamat or what ever else you want, what subs you running whats your over all goal and plan maybe sketch somthing out and post it My youtube channel https://www.youtube.com/user/ghostlyrich Mazda 3 2006 Build (R.I.P) http://www.stevemeadedesigns.com/board/topic/172728-mazda-3-2006-stealth-build/ Volkswagen GTI 2011 Build http://www.stevemeadedesigns.com/board/topic/192979-vw-gti-2011-build/ Jeep 2015 Build http://www.stevemeadedesigns.com/board/topic/201493-my-new-jeep-2015/
evermaxx Posted September 30, 2013 Author Report Posted September 30, 2013 Thanks. So it's worth the 2/0 over the 0/1 ofc? Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
ghostlyrich Posted September 30, 2013 Report Posted September 30, 2013 Thanks. So it's worth the 2/0 over the 0/1 ofc? power is always good My youtube channel https://www.youtube.com/user/ghostlyrich Mazda 3 2006 Build (R.I.P) http://www.stevemeadedesigns.com/board/topic/172728-mazda-3-2006-stealth-build/ Volkswagen GTI 2011 Build http://www.stevemeadedesigns.com/board/topic/192979-vw-gti-2011-build/ Jeep 2015 Build http://www.stevemeadedesigns.com/board/topic/201493-my-new-jeep-2015/
