4 15 wall build in extended cab of ford ranger
toolshed
IsTherE Any Other Options , Its Going To Be Hard To Open The DoOrs Rolling Down ThE Road haha
Pretty sure a lot of systems lose with everything sealed up. Maybe even safe to say most, I know mine does, so does mine friend. Roll the windows down and I get louder and lower. Also If you go to shows (idk if you go regularly or not) you'll notice a lot of guys demo with only the driver door open or with both windows down. Just how a lot of system react to being in a closed surrounding
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Bass notes are everywhere between 15-60 feet long. When you trap them in the 5-15' long cabin of a vehicle, you cause refractions and cancellations which in turn, cause the sound pressure to drop.
This is the exact same reason why sealed boxes don't perform as well as vented boxes and it's the exact same reason why transmission lines perform better than conventional vented enclosures.
Bass notes need room to do their thing without being fucked with by solid objects. ;-)
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
So A 4th Order Would Probably Do better Than A Flat Wall
No probably about it. It would do much better.
There is a build on this site where a guy has a 4th order bandpass setup just like that. I think his username is RockfordCole. Itsa couple of 15s in a Colorado. Subs fire up into the port and the port shoots forward
Here is the link to the build:
http://www.stevemeadedesigns.com/board/topic/163987-4th-order-wall-in-chevy-colorado/?fromsearch=1
sweet man, thanks for the link... i notice that everyone seems to be runing the sub in a single chamber on the front side... is there any advantage to running them in all divided... I'll probably run 3 15s and just trying to figure out the best way to do it.
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
