roblos416 Posted October 1, 2013 Report Posted October 1, 2013 First of all let me start by stating I have no dd1.with that being said I was reading my zrx3000.1d owners manual and it said to adjust the level on my amp to the voltage output of my radio, And it also states that it is not recommended to exceed the 12o clock position on the bass eq which would be 5db.I would like to get some knowledgeable input on this topic! Thanks in advance
john253a Posted October 1, 2013 Report Posted October 1, 2013 Personal I start with NO BASS BOOST LPF approx 70hz And if you no your voltage of hu and iput setting in amp (0-5v or 5-10v) you could decide the number of markings on amp and estermate where you should set your gain (this is by no means accurate but a good starting point)
