XS Power
wassup boyz!!!
here my setup... stock battery with stock alt... 900wrms kenwood amp and 200w pioneer amp...1x 12'' pioneer ts-w3002d4 1000wrms on the kenwood,and 2x power-acoustic 4'' at kickpanel on the pioneer amp...and 2 lanzar 320w as component in front plug in the headunit...oh and 1k capacitor
the big 3 is not complete yet,only the power wire was done,and im waiting the get the wire and connector to do the rest...but i don't think it will help that much to stop headlight from dimming when system is cranked...
so what's my best option???
i was thinking to do a big3 with 1/0awg wire....or change my original battery....or change the alt to an HO one....or add a second battery
the setup is currently on 4g wire...but im not sure if the ground at amp is really well done...
i know it not a comp setup,but im upgrading piece by piece to get a decent spl system...
i know that i will probably add an other amp for the component,a 4channel,and some 6x9 and tweeter...
and looking for used stuff...
can i fit battery togheter even if are not the same??
2x SSA XCON 15''
2 basworx 3000.1d
1 kinetik 1800 & exide 85amph
skyhigh 1/0 all-around
Grimreaper spl team co-president
Hey have Jeep Commander here 3.7 motor. Had same issue here. Do big 3 run 0 from alternator straight battery. Do no upgrade the other wire that goes to pcm in front behind battery. You will need to also run 0 Ground to engine also for alternator on this vehicle. Run 0 ground to battery also. You also will need extra battery also. I installed XS Power D3100 in mine. This will stop it from dimming. Do you have 160 amp alternator?
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
yep,i have the 160 amp alt...allright so ill do the big 3 in 0awg wire and add a second battery...hope this will be ok...thanks for the advise!!!
2x SSA XCON 15''
2 basworx 3000.1d
i found a kit on kijiji,150$ for a 1400 kinetik batt,20-25ft of 0awg,and a battery isolator...i think im on buisness now!!!
the next thing i need to know before installing all this,is the order of the battery...should i keep the old(original) battery in front and drop the kinetik in trunk?or the opposite??
or maybe only the kinetik may be ok for the whole system?
is it ok for having 2 different battery in the same system??
2x SSA XCON 15''
2 basworx 3000.1d
If you have a lead acid battery then you don't want to run it in the cabin of your car. Only sealed batteries are applicable in cabin.
Eclipse cd7000
oh...so the old batt stay under the hood and the kenetik at the back....got it!!!
so it dosent matter if they are not the same type (acid and gel) even plug together?
i was worried about the fact that my old batt is 600 or 900 amp,and the new one is 1400...i was thinking that may cause an issue...
2x SSA XCON 15''
2 basworx 3000.1d
  • 4 weeks later...
november update:
kenwood amp is dead...my bad,i load too much weight on it when i got my new house...so now i have an good old alpine mpr-1000,for 1000W rms on my sub..
it push far more than the kenwood,so the power is going down much more...i did the big three with 4awg,change my 1 farad cap for a 6 farad,it help a little...but still,if i crank the gain to .3V,light dimmed....i was looking to boost my alt,but the guy ask my like 250$ for,and im a nat...lolew house owner,and second baby is on the way...so ill be killed by my girlfriend if i spend that money on that alt... and XS battery in quebec are way too much $$$ for my budget built...so ebay will be my friend on that
i found a battery brand that look affordable for what im looking...the thing is how much power do i really need??
106$ total for this one
Volts12 VAmp Hour35 AHChemistrySLA / AGMTerminalNut & Bolt (NB)Length7.68 inWidth5.16 inHeight7.13 inWeight23.15 LbsWarranty1 yearQuantity1
http://www.ebay.ca/itm/Power-Sonic-UB12350-U1-12V-35Ah-Sealed-Lead-Acid-SLA-Brand-New-Battery-/131020645403?pt=US_Rechargeable_Batteries&hash=item1e8170641b&_uhb=1
a smaller one for 65$ total
Volts12 VAmp Hour18 AHChemistrySLA / AGMTerminalNut & Bolt (NB)Length7.13 inWidth3.01 inHeight6.57 inWeight11.90 LbsWarranty1 yearQuantity1
http://www.ebay.ca/itm/Power-Sonic-Black-12V-18AH-NB-T3-High-Current-Battery-Replaces-Kinetik-HC600-HC6-/380745919032?pt=US_Rechargeable_Batteries&hash=item58a639aa38&_uhb=1
for example,kinetik hc800 are somewhere between 160-200$ total...for the same power as the first one at 106$
should i try it??? is the smaller can be ok for what im looking??
2x SSA XCON 15''
2 basworx 3000.1d
This topic is now closed to further replies.
