look we are talking about the pre-outs on the head unit. Not the speaker level outs. No one who buys the prs that i know of, buys it to use the speaker outs. Why they even put an amp inside is beyond me. And the prs80 does 62/62 at like .015%thd.
  • Like (+1 Rep) 2
When do you run your stereo at 62 never!!!! Asking tor trouble.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
just stfu and get out.
OP, did you adjust the EQ after you set gains? did you turn on bass boost or loudness after you set gains? anything like that? Are you wired down to .25 ohms? I see you are running two d1 subs so i have to ask.
F.y. strangeduck I don't play games on here.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
im running them at 1ohm. It could be the lpf thing but as all amps it only gives you two numbers so its hard to adjust. and the subs get pretty warm not super hot. but to an extent where you can smell a little bit. on 80prs the loudness I have off. and the eq is mostly flat I only do like +1 or 2 on certain ones. I don't use bass boost at all.
08 Ford F150
I would use the lpf on the head unit. You might check it as it could be lower than your amps lpf causing a loss in output.
Well first let me say I really liked the idea strange duck had for tuning the bass with -10db on the dd1 with the sub level maxed, and then using the -5db tone and turn down your sub level until its clean to compensate for different music. I tune just with -5db but that's just me and I mostly stick with decaf so...
Second... Yes the 80prs is less then 1% thd at 62/62. Its a bad ass headunit.
OP. just make sure all bass boost, loudness, and other EQ things are turned off. Those are all bad. As far as boosting things +1 on your EQ.. That can work, but generally people will tell you to cut frequencies around it rather then boosting the lower ones. So instead of raising 1k... To lower 80hz and lower 1.5khz... That kinda idea.
Other then that it seems like your doing everything right. Another contributor would be voltage. If your voltage dips below where you tuned it with your dd1 then that could introduce clipping too. I tune with my car off so I'm safe till about 12.5volts.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
