wiring question
Ok, so im almost ready for finals. I wanted to connect my subs to 0.5 ohm today, but came accross a little problem.
Ive got 2 dual 2 ohm subs, so I hooked them up to 0.5 ohm. When I wanted to connect them to the amp, I saw that my amp looks to have 2 cahnnels. I know its not two channels but it still has two +'s and two -'s
How should I connect the subs?
then im rambo bitch
its not but you can hook one sub up to one set and the other to the other set and it will connect them internally
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
wire each at 1 ohm..... the run each sub to the amp it will bridge it internally.. or you could bridge it and run it to just one + and one -
youre amp is a mono amp, even tho it has 2 + and 2 - doesnt mean much , on the inside of the amp both of the + are joined together and both of  the - are joined together , so wire your subs up in the box to the ohm load you want (if you will run that load 100% of the time or you can run all 8 wires out of the box, then connect the wires how ever you have to , so you can get different ohm loads for different purposes, but just ingore one of the +- on the amp and youll be fine wont hurt anything now or down the road :^
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Ok mate. Wire both sub's voice coils in parallel like this:
Now each sub represents a single 1 ohm load.
Now, your amp has a pair of output terminals, it is still a monoblock. That pair is actually wired in parallel anyway so it makes no difference really. Just wire each sub to a corresponding + and - (One per terminal if you will).
Viola! you now have an amp seeing a .5ohm load.
Be careful with how many speaker cables you have coming out of your enclosure, you may get bumped up a class due to the conductor rule. :)
Cheers
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
PS: The diagram you drew was for a .5ohm load.
My Youtube Videos
  • Who's Online   1 Member, 0 Anonymous, 1307 Guests (See full list)
