I gave away a roll of fatmat to a member here. Mostly because he didn't have the funds for some deadener and I was more than happy to help.
Bad idea going cheap unless it's free (like what I gave dude). It falls off doors onto widows, gums up regulators and causes herpes...
It won't effect the sound.
Exactly..
I have 120 mm in my roof
Creating a barrier on the roof -let alone out of vibration damping material- has very little point to it, unless you have sound coming directly from above you car. This is because the window line is the weak link behind that.
To build a barrier you will need another material such as mass loaded vinyl (MLV) and lead sheeting. As these two object have very high mass and a resonant frequency well below the audible spectrum.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
I don't have windows and I also added quarter inch closed cell foam to it. I have a Ford Transit Connect. It is poorly insulated and has extremely loud road noise. After installing I noticed a huge difference in noise as well as climate changes. Now do you get it?
For building a barrier it is best to think of it as building two thirds of a bubble. You want mass loaded vinyl covering all of that two thirds.
Before you do that you need to put about a one eight layer of closed cell foam between to decouple the vinyl from the vehicle.
Make sure you use vinyl contact cement to secure MLV to the CCF, or vinyl specified Velco strips (not the same Velcro strips you buy at Lowes)
Somewhat ninja'd
Check out Evercoat Q Pads make sure you have a heat gun.
I have never known that fiberglass was a good acoustical dampening material. I assume that is what it is as it never directly states it's composition, and every other product that company offers is fiberglass.
I love murdermat myself
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
