Center console sub box advice
Im trying to figure out what i should do for a center console box in a single cab ranger. My idea is a coulpe 8s or 10s. my problem is air space i want the most deep bass i can get. Maybe one 12?? idk whats your ideas for a speaker that will be good for limited air space. vented or sealed. its going to be wood base with fiberglass and theres bucket seats and i can go as high as the bottom of the back window.
Thanks
94 Ranger Std. Cab Bagged and Bodied
Audio under construction:
Center Console Ported Wall
4x SA-8 D2
Soundqubed 2200d.1 @ 1Ohm
Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721
2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro
4x Fosgate Punch 300.1
Big 3 Upgrade Kandywirez
XS D3400
09 Lancer Turbo
1- 12" DD 512B
SoundStream Rub1000.1 (turned way way down)
Avix-930bt
do 2 tens down firing with port to the back
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
What kind of tens and are u talking inverted subs with the mag showing?
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
no not inverted. face the subs in the box down towards the floor with the box spaced high enough to allow about an inch of clearance with the sub at full excursion. This allows the subs to load off the floor and the port to load off the rear wall. Which subs depends on your budget, amp, and electrical. Get me that info and I can make a good recommendation.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
If you're on a budget, SA-10's would work. Bang for buck, XFL 10's from everything I've heard. Personal experience, Fi SSD 10's rock :) 2 SSD 10's in 1.1 cubes a piece, so if you could grab 2.6 cubes net(subs displace .18 a piece) and do a 6 inch aero out of the side of the back of the box, firing into the b-pillar, you could get some really great results.
Problem is I can build anything but design is not my cup of tea any way I could have some design a box for me? How would I go about doing that?
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
Post some dimensions lol. I've give a shot at it.
I think im going to get a Sundown SA10 from my buddy and use that in the center console box. Whats everyones thoughts or should i go a defferent route
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
Go for is. The sundown SA series subs are very good.
Nothing for now...
Did you get that scar tissue when you got your vagina installed?
I'd grab Adam's ass and look him in the eyes for a demo of nates truck.
Should i go with a 10 or 12 i dont have much room as its going to be a center console box in a bodydropped ranger.
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
  • Who's Online   0 Members, 0 Anonymous, 3296 Guests (See full list)
