Rockford BLD sending amp into protect.
Installed the Rockford line driver, turned the gain all the way down, bass on the stock head unit is all the way down. Car is a 2012 equinox. Not sure what the issue is, the output seems to be right about the 5 v the soundquebed 2200 says to give it. As soon as I turn the head unit up to where I usually do the amp goes into protect. I am using the high level inputs if that matters. Any suggestions. Also right now it has just the big three and 0 gauge, stock battery. I know that's not to good, can low valtage send the amp into protect? Plans are to try and fit a second battery in the back.
Why not try the low level Rca's , and switching from balanced and unbalanced. Because it sound like your voltage from the driver to the amp is to high.
truthsayer
Ok switched it to unbalanced and now she is moving like she should. No alternator whine goin on, stock alt is 145 amps, I know not much but better then most lol. I am thinking now with a nice bat in back it should be doing well. Thanks guys.
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
