X-12 Blowthrough build Ram 1500
I'm basically starting from scratch with my system and it looks like this forum can help shed some light.
Right now I've got 2 JL 12w6s in a custom box under the back seat of my quad cab, running off an audison sr1dk. Sounds alright, but the box is WAY too small for the subs and I never could get the response I was looking for from the subs.
I figure if I'm going to look into a blowthrough, I might as well get some subs that'll give the me SPL I'm craving. The X-12s look like an amazing dealing beater sub. So now the question is: Would I notice a difference with the Z series? Two or three subs? How much power? How big of a box/port into the truck?
Any info would help. Thanks guys.
Edited by SUSS01
You will notice a huge difference between a w6 and a sundown x. As far as how many they more the better in a blow through as long as you can give them proper space. For the box since it is a fourth order I would do a 4th order. Make sure you think about proper electrical to supply the amp for the subs also as here lately that seems to keep getting forgot. I have more money in my electrical than I do my subs and amps as do most others here that have a properly built system.
Edited by g2shuck
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
the three x 12s will move alot more air on the same power as the two z 12s
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Im not a fan of uneven amounts of subs so i vote for 2 z's
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   1 Member, 0 Anonymous, 548 Guests (See full list)
