jordan23 Posted October 15, 2013 Report Posted October 15, 2013 hi, i currently have a re audio srx 15 dual 4 ohm in a 4 cube box tuned to 32 with the sub up and port back. Now im wanting more and i have two different ideas im tossing around. First one is get a second srx and make a 7 cube box tuned to 35 with subs facing back and a aero port on the side. My second idea is doing a recone on the 15 i had before which was a mach5 ixl 15 http://www.istonline.ca/mach5_ixl_15.html i bought it used and it would bottom out on anything lower than 30hz on 400 wrms in a sealed box with no clipping and one day it bent the voice coil when it bottomed out. whats your opinion on what i should do? either one i will be geting a 1000 wrms not sure what amp yet. Thanks, Jordan
UnderratedDB Posted October 15, 2013 Report Posted October 15, 2013 hi, i currently have a re audio srx 15 dual 4 ohm in a 4 cube box tuned to 32 with the sub up and port back. Now im wanting more and i have two different ideas im tossing around. First one is get a second srx and make a 7 cube box tuned to 35 with subs facing back and a aero port on the side. My second idea is doing a recone on the 15 i had before which was a mach5 ixl 15 http://www.istonline.ca/mach5_ixl_15.html i bought it used and it would bottom out on anything lower than 30hz on 400 wrms in a sealed box with no clipping and one day it bent the voice coil when it bottomed out. whats your opinion on what i should do? either one i will be geting a 1000 wrms not sure what amp yet. Thanks, Jordan what vehicle and how much power youre running
g2shuck Posted October 15, 2013 Report Posted October 15, 2013 is it a hatchback. 7 cubes is a bigger box them most relize 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
jordan23 Posted October 15, 2013 Author Report Posted October 15, 2013 car is a 4dr civic sedan, measured the box out to 32 wide 26 deep and 17 high max size
g2shuck Posted October 15, 2013 Report Posted October 15, 2013 that is only 6.70 cubes before sub or port displacement 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
jordan23 Posted October 16, 2013 Author Report Posted October 16, 2013 yes sorry its 6 cubes after displacement.
newschoolsoundz Posted October 18, 2013 Report Posted October 18, 2013 id go with 1 15 in slightly larger box maybe one of more power
Maebros Posted October 18, 2013 Report Posted October 18, 2013 i have 2 12s in a 3^2 box in my civic and im hurting for room i dont know how you are going to fit 2 15s HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier On 8/8/2012 at 4:50 PM, Brandon15zzz said: I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster. On 8/29/2012 at 12:25 AM, ILoveBass21 said: he could blow a sub powering it with a potato.
newschoolsoundz Posted October 18, 2013 Report Posted October 18, 2013 or even 2 12s is better then 1 15 an he said hes already got 4 cubes box in with room to spare my civic holds just over 7 cubes
