[email protected] Posted October 19, 2013 Report Posted October 19, 2013 So I'm going to set up a small 3 way amp (1 channel for sub and 2 channel for front speakers) on my new car and want to use the factory deck. My question is do I use the front "midbass/tweeter" or the rears "full range" speakers
audiofanaticz Posted October 19, 2013 Report Posted October 19, 2013 rears would be your best choice if its a full range signal.
[email protected] Posted October 19, 2013 Author Report Posted October 19, 2013 thanks. and i will be able to use the rears speakers off the deck and the fronts of the amp correct?
ghostlyrich Posted October 19, 2013 Report Posted October 19, 2013 thanks. and i will be able to use the rears speakers off the deck and the fronts of the amp correct? if i were you i would do a 4 channel for the speakers and the a mono block for the sub. as for keeping the stock head unit make sure you use a good line out converter like a lc2i or lc7i that way you don't wreak your speakers by adding bass in line My youtube channel https://www.youtube.com/user/ghostlyrich Mazda 3 2006 Build (R.I.P) http://www.stevemeadedesigns.com/board/topic/172728-mazda-3-2006-stealth-build/ Volkswagen GTI 2011 Build http://www.stevemeadedesigns.com/board/topic/192979-vw-gti-2011-build/ Jeep 2015 Build http://www.stevemeadedesigns.com/board/topic/201493-my-new-jeep-2015/
[email protected] Posted October 19, 2013 Author Report Posted October 19, 2013 ywees Thank you thanks. and i will be able to use the rears speakers off the deck and the fronts of the amp correct? if i were you i would do a 4 channel for the speakers and the a mono block for the sub. as for keeping the stock head unit make sure you use a good line out converter like a lc2i or lc7i that way you don't wreak your speakers by adding bass in line Thanks. That's what I would normally do. But i just bought a Fiat 500 and it has very limited space. and the 3channel amp I'm going to use is not very powerful at all. I'm not looking for the best sound quality I can get, I'm just looking for an affordable upgrade (200-250$ total). Once I get myself a car with more space again I will do a more proper install.
[email protected] Posted October 19, 2013 Author Report Posted October 19, 2013 thanks. and i will be able to use the rears speakers off the deck and the fronts of the amp correct? if i were you i would do a 4 channel for the speakers and the a mono block for the sub. as for keeping the stock head unit make sure you use a good line out converter like a lc2i or lc7i that way you don't wreak your speakers by adding bass in line I've seen you're build on YouTube by the way. Looks good man.
ghostlyrich Posted October 19, 2013 Report Posted October 19, 2013 thanks. and i will be able to use the rears speakers off the deck and the fronts of the amp correct? if i were you i would do a 4 channel for the speakers and the a mono block for the sub. as for keeping the stock head unit make sure you use a good line out converter like a lc2i or lc7i that way you don't wreak your speakers by adding bass in line I've seen you're build on YouTube by the way. Looks good man. thanks man. My youtube channel https://www.youtube.com/user/ghostlyrich Mazda 3 2006 Build (R.I.P) http://www.stevemeadedesigns.com/board/topic/172728-mazda-3-2006-stealth-build/ Volkswagen GTI 2011 Build http://www.stevemeadedesigns.com/board/topic/192979-vw-gti-2011-build/ Jeep 2015 Build http://www.stevemeadedesigns.com/board/topic/201493-my-new-jeep-2015/
